Two 2 Ohm DVC Subs Wiring Help
it looks like you have your subs in series in your picture, so you would have two 4 ohm speakers, wiring the +'s and -'s to the amp would leave you a 2 ohm load. I think you got it.
he needs to do it exactly as the diagram says, and how we have confirmed not once but twice... series each sub up to 4 ohm, then take your remaining +'s and -'s and put them into the corresponding mofo spot on the dat dang amp son!
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
Tis the exact box I am using with my Punch P3 10's wired to 1ohm at the amp. I also have dual terminals on my mono amp. I wired each 4 ohm voice...
14
It also lowers the amps efficiency and raises the current draw.
527
Sovereign12
Sovereign12
Grand Forks, ND
Sovereign12
audiobaun
    May 19, 2024
    May 19, 2024
