Tymphany Lat 250
  • 2
SoCalBean420
Cali
Tymphany Lat 250
View Listing
Pair of tymphany lat 250. These only have light testing on them. Perfect working order.
Tymphany LAT250 Linear Array Transducer
The patented dual-motor LAT 250 is designed to provide strong bass performance in a new vibration-free, cylindrical form factor. The driver may be configured for use in sealed, vented, bandpass, or open-baffle enclosures, and provides high bass output from a very compact transducer. In typical applications, the Tymphany LAT 250 has mechanical vibration more than 90% less than comparable loudspeakers, even at full output. Paired with the appropriate high frequency driver, the Tymphany LAT 250 is an ideal solution for lifestyle consumer electronics products such as flat panel TVs and sound bars, MP3 and cell phone docking stations, multimedia PCs, and other small devices. Note: The nominal impedance is calculated with both 4 ohm coils driven in parallel. Tymphany LAT 250
Specifications: • Power handling: 100 watts RMS/200 watts max • Le: 0.27 mH • Impedance: 2 ohms • Re: 2 ohms • Frequency response: 60-1,600 Hz • Fs: 60 Hz • SPL: 84.5 dB 1W/1m • Vas: 0.31 cu. ft. • Qms: 3.4 • Qes: 1.0 • Qts: 0.79 • Xmax: 3 mm • Dimensions: Overall diameter: 10.2" x 3.5", Cutout diameter: 9.4" x 2.7", Depth: 1.35" (half of total diameter).
I was going to run those same Jbl's before I went insane about the car. Glad I would've made a good choice.
  • Locked
THESE ITEMS WILL BE REMOVED FROM THIS FOR SALE THREAD ON AUG,16.2022 @9PM CT THANKS
SoCalBean420
SoCalBean420
Cali
teflonjedi
    Apr 27, 2024
audiobaun
    Apr 27, 2024
