Understanding Ohms and Amp channels.. HELP!
MCM5595
Okay i just wanna know how wrong i am here...
If I'm looking to get 2 12 inch subs that run at 300 RMS dual voice 2 ohms, i want to get a 2 channel amp that runs at 300 RMS at 2 Ohms.. so then each channel gets 300RMS and/or a 4 channel amp at 2 Ohms that runs 150 RMS each channel then bridge to channels to make 300RMS to each subwoofer (I'm disregarding 4 Ohms amps because i herd they were more expensive)...Or would bridgein the 4 channel 2 ohm amp up the resistance and make it a 4 ohms?
now if i get 2 12s that run at 300RMS dual voice at 4 ohms... finding a amp that is 300 RMS at 4 Ohms is expensive ( or is it?) so i buy a amp that is either a 2 channel (being 300 RMS each channel) or 4 channel being (150 RMS each channel) AT 2 ohms so i bridge the 4 channels to simulate a 2 channel , i run the subs parellel so the amp thinks its a pair of 2 ohm subs but really it is two subs that are 4 ohms... honestly this is all information that i have observed from the internet and im trying to find out if i peaced it all togther
please correct me where im wrong... wich probally is everything :p
Thanks.
wow.. hmm.. you might have lost me through that.. you can run a mono amp too. you dont have to have specific channel of amp.. plus you can weire your speakers different. dual 2 ohm coils you can wire subs to 4,2,1.. lots of options...
holy shit, lol.
Get a mono amp...and just wire the subs together for a final load of 1 ohm, or 2 ohm. Really easy to do, check out Rockford Fosgate's wiring wizard
Here
Since this is subwoofers we are discussing, you could find a mono (1 channel) amplifier that gives you 600rms @ 2 ohms for 2 DVC 2 ohm woofers; or an amplifier that gives 600rms @ 1 ohm or 4 ohm for 2 DVC 4 ohm woofers.
You could also potentially end up @ 4 ohm or .5 ohm, so wiring will be key. The above options tend to be the easiest on a budget.
Since this is subwoofers we are discussing' date=' you could find a mono (1 channel) amplifier that gives you 600rms @ 2 ohms for 2 DVC 2 ohm woofers; or an amplifier that gives 600rms @ 1 ohm or 4 ohm for 2 DVC 4 ohm woofers.
You could also potentially end up @ 4 ohm or .5 ohm, so wiring will be key. The above options tend to be the easiest on a budget.[/quote']
not alot of 600watt amps out there .5 stable
ya.. depends on what you are looking for. If you want as much boom as possible go the 1 ohm route. if its too much or you just want a little punch with your music got 2 or 4.. just depends on what sound you are going for
Basic Car Audio Electronics
This website will help you learn quite a bit on anything car audio related. Specifically section 58 deals with series/parallel impedance and wiring.
The link that plugitin posted is also good to see what your wiring options are for a specific set of coils.
And you base the sound differences caused by impedance on...? Just curious //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Also OP, there are a good amount of amplifiers that can work for this application in a low budget range, since that seemed important to you.
wat
just wattages. you get a 600 watt amp and wire it at 1 ohm and get 600 out of it.. wire it at 2 and get 300. less watts=lessboom=lessdistortion. then you could have an sq type setup wire it at 4 and not have much punch but have clean bass.
im looking to feel the subs hit.. thats about it im not worried about vibrating my mirrors off or anything just a light feeling and good compelementing bass... ill be running the system in a SUV im also looking for it to last i dont wanna have to keep spending money on blown woofers XD, although i read that if you go down to 1 ohm some subwoofers cant handle it so is it good to match the subs ohms and amp ohms to insure that there is no heat buildup?
Answer the question.
Also OP' date=' there are a good amount of amplifiers that can work for this application in a low budget range, since that seemed important to you.[/quote']
Let's if i can give my input too. 180 Watts is the maximum power your speakers can handle. And it is 4 ohms. And you're trying to find the...
27
Yeah, if you haven't bought em yet, then get a matching third sub. I would wire them to 1.3ohm, unless for some reason, you have some really...
Follow the wiring diagram for the final 1 ohm load for the 6.5s and the 1k amplifier...
Thank you for all your help and I'll let you know how it all turns out. I'm putting it n a kia optima. I hope that it sounds as good as i think it...
10
MCM5595
MCM5595
Boston, MA
Bumpin' Goalie
    Jun 1, 2024
    May 31, 2024
