Viper Remote won't charge
  • 5
toyopl
Hey, I have Viper 5901 system in my car. I was away for a month for christmass and after I came back I see the LC3 2-way remote battery died, but I plug it in and it won't charge. I tried 2 different cables and also tried charging from laptop, ps3 and straight from plug aswell. anyone knows what the issue might be ?
Its DEI. I have python 872 and my FOURTH remote in a year and a half stopped working.....My two other friends are having the same issues...return it and look for something that ISN'T DEI
DEI makes plenty of great sh!t.
I've said it before and I'll say it again, the 5901 series and (other brand equivalent's) are a bit overrated, as far as reliability. I would've stuck with a 5900 or better yet 791xv. the latter about NEVER fail. All this new technology is obviously not perfected yet
OP good luck with your replacement if you can get one (shouldn't be a problem if you got it installed authorized)
피크를 사용하지 않을 계획입니다.
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
12
642
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
8
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Actually, I think I had the adjustment knob turned down while I was setting gain! Rookie mistake
31
4K
toyopl
toyopl
Milton, On, Canada
Havoc Evan
