Voltage Problems, Please Help!!!
  • 5
I checked today and it was at 14.1-14.4 at idle. And i was running the amp at 1ohm tuned conservatiley
---------- Post added at 05:42 PM ---------- Previous post was at 05:42 PM ----------
I checked today and it was at 14.1-14.4 at idle. And i was running the amp at 1ohm tuned conservatively
Was that under load? Where was this checked? That's what you should be seeing though.
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
570
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
rlambert02
rlambert02
PHX, AZ
rlambert02
    Jun 1, 2024
    May 31, 2024
