What amp should I get for 4 Alpine SPR-60 6-1/2" 2-Way Type-R Series Coaxial Speakers
Hickom
So I just bought 4 Alpine SPR-60
6-1/2" 2-Way Type-R Series Coaxial Car Speakers for my 2002 Saturn SL1
I want make these speakers as efficient as possible. I'm a rookie with car audio and I don't really know what I'm doing. Help Please
Specs of the speakers
Peak Power Handling 300 watts
RMS Power Handling 100 watts
Sensitivity 88 dB
Frequency Response 65 - 28,000 Hz
Impedance (Per Voice Coil) 4 ohms
I just want the sound to be clear and loud because after I get the amp I want to put a sub in the back and an additional amp for that.
clear and loud depends on the amp and speakers you buy ,i would be inclined to tell you to take back one of those sets of speakers and get a set of components for the frt doors instead.it will sound alot better.coaxials just dont get that loud unless you are paying 200 or more for them.they just dont put quality in coaxials anymore
I would have bought Precision Power P900.4. The rating is 4x140watts at 4ohms. More importantly, it less than half the size of ONX4 and runs cooler, a great benefit for a relatively small price premium.
Pioneer lists the wattage different than sonic. Pioneer says That amp listed will do great with these speakers. You can play em at 125w no...
4
Have you check to see if the prefab would fit...
13
For the sub you want to run.. The 700.1 will be more than enough power and enough Head room for that sub. For the Price? And the sub you are...
13
Your skar amp will catch on fire if you go full power?
8
I'll suggest a JP8 amplifier. I believe you can wire your sub to 2 ohm. It's Dual voice coil 4 ohm, correct? JP8 @ 2 ohm does 900 watts.
Hickom
Hickom
United States
Hickom
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
