What amp to do .5 daily?
d9/sundown 4500/500.1/40.1... not a whole lot of difference between them, and they'll all do it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i'd guess they'll all do over 5k at .5 ohms.
just a heads up the electrical will cost more than the amp high output amp external regulater to set voltage at 15.4v multiple runs of 1/0 big three as loarge of a batt as you can get to fit up front and a min of 5 large batts out back depending on your listening habits watch the voltage if it drops to much add more batts
I know my electrical has to be beefy so no shock to me
and I already have a 220 amp alt...I was gonna use a d3100 under the hood...then whatever batt's I need out back
soundstream makes a DTR3400.1 which is 3400@.5 ohm from the factory, so you get an amp that is manufactured to run as low as you want, with support to boot if something goes wrong.
So I looked more into the crescendo 3k and Im liking it... 4k at .5 and they warranty it for 2 years even at .5
And I read that the new heatsink they're coming out with will do a bit more power. So i think im going to go with that and the 4 channel they have
137
368
  • Locked
666
Amp
483
kunzy420
kunzy420
E-town
kunzy420
    Jun 1, 2024
    May 31, 2024
