What are the best methods of surge protection in car audio?
  • 4
I know that circuit breakers and fuses are used in car audio to protect surges of power from damaging electronics, but are there other options available?
In home audio, there are components called Line conditioners. They continually test the power and shut it down when there is inconsistent surges or spikes. If there is a spike. it disconnects the supply to the connected components and protects the equipment.
Similarly, there are car jumper cables that do the same thing. They test to make sure the power source is safe and connected properly before it supplies power to the drained battery. This technology is run by a microprocessor. anyway....
Is there something like this for car audio? I mean are there hundreds? thousands? of people damaging their equipment from power surges. ruining equipment? is there a need for something like this in the car audio. I am trying to get a grip on the products available and potentially the need for a new product.
In all car audio equipment, there is already provisions for that in the item's power supply. For instance in head units there is a dc to dc converter with capacitors to keep up with low voltage issues.
Line conditioners and surge protectors exist in home audio because they all initially receive 110~120v AC, which is quite dangerous and can kill people and start fires. Usually the AC to a house is quite stable but things like thunderstorms, lightnings, large industrial motors and high-electricity demand within the house can wreak havoc to the electricity going into your electronics. Surge protectors are made to filter out AC line noise from nearby electronics, in an event of overvoltage it'll absorb that extra incoming voltage so it doesn't fry your electronics(that's why you should replace them after a known overvoltage condition). Some surge protectors also have a "brown-out" preventer which cuts power to its outlets in an event when the AC voltage drops below 100v or so. AC Line conditioners are made to not only protect your electronics from "bad" incoming voltage, it also make sure the voltage going to your home electronics stays around 117v AC.
In car audio there isn't really much to spike voltage unless the alternator is faulty or your car got struck by lightning, but 99% of the time it is low voltage that kills car electronics. I would say one or more extra batteries can act as DC voltage line conditioners as long as you can keep it charged.
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
513
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
494
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
9
617
I hear ya. There are so many good deals on speakers too. My kid is 16, so loud is better than SQ. LOL... I really like the sound of the PPI...
15
Miggy1582
Miggy1582
Klamath Falls, OR
Wingman0121
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
