What do I need?
invertMASA
Im working on putting a new sound system in may car, Its a 2010 impreza sport. What would the adapter be I need to get RCAs and keep all 4 channels? I found some but they only splice into 1 speaker, so that would just send that channel to the amp and thus so all the other speakers giving me a mono sound right?
Want to keep it looking stock. So dont want to buy a new deck
if all you are planning on doing is a sub and amp then that will work. if your looking into upgrading everything but the head unit I'd go with a processor. Processors can be expensive though, pricing from couple hundred to a thousand. do some research on processors within in your budget and check back before you buy. At least I would suggest checking back before you buy.
470
365
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
400
606
invertMASA
invertMASA
United States
CrossoverOre
    May 31, 2024
    May 24, 2024
