What is a good amp
People that describe what sort of power they need in a 4 channel by telling us the need XXX total power sound like the flea market brands that add all the max ratings up and slap it on an amp so kids can feel cool when they say they have a 2000 watt amp /rant
How else would you know what to recommend if you don't know what I'm looking for? You don't buy tires without knowing what size you need do you? I also put in my post what I'm trying to replace. I'm not just looking to say look at me I have blah blah watts. I'm wanting to replace something I already have with what is available in the market today.
You could also buy my PPI A404 amp //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Good OS sq
For that range, i would probably take a look at some oldschool amps. That way you can find top notch brands and quality for very low prices. likely used but as long as it works.
I am looking for a good 4 channel amp around the $200 to $250 range.
Reasonable $ range.
If new, then the MB Quart already mentioned, plus Lanzar OPTI's or Massive Audio Nx4.
If used... ? Lots of possibilities for that money
EDIT: lol, get called away for a minute and 2 posters beat me to it
For a little under $200 I highly recommend this: Amazon.com: MB Quart ONX4.125 1000W RMS, ONYX Series 4-Channel Amplifier: Car Electronics
It gives immaculate power with decent quality for almost any price range, but only costs $170. Also can be bridged @ 4 ohms 500w x 2
THIS^^ Hard to beat in the price range. I wouldn't compare it to overall quality of those punch amps though but nonetheless. You might get lucky and find a used Arc Audio Kar300.4 for around 250. That would be a good option.
I'm running it to two 3-way truck boxes with 12 inch subs. The 400 watts I'm looking for is total watts into 4 channels. That way when I bridge it I'll get a little over 200 per channel.
I have searched google and there are hundreds of amps that are out there. I thought I would come to a site that had people who could give me some real knowledge and info instead of some manufacturers bs.
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
107
6
353
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
655
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
477
slat
slat
southeast, missouri
audiobaun
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
