What is your opinion on these componet speakers?
  • 2
i believe the general consensus is that the kappa's sound tinny, should step down to the references if you want infinity
hmmm, OK
what about these?
Infinity Reference 6830cs
Power Handling, RMS 90 W
Power Handling, Peak 270 W
Frequency Response 49Hz – 21kHz
Nominal Impedance 2 Ohm
Sensitivity (2.83V @1m) 93 dB
Reference 6830cs - Infinity
I don't even think you need to do that. You can use WiFi to connect wireless Android Auto but doing so kick out the units ability to self stream...
846
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
Sundown does underrate their amps. And by alotmon the salt line The salt 200.4 I would bet would walk all over the t1000-4 but the Rockford is a...
orphe
orphe
Houston
orphe
maylar
    Jun 2, 2024
    Jun 1, 2024
