what kind of amp for two 12"s
  • 6
i lol'd.
The Kicker ZX300.1 puts out 300wRMS @ 2 ohms. It's a perfect match for your subs, and should retain its value and handle some abuse.
Kicker 10ZX300.1 300W RMS Class A/B, ZX Series Monoblock Subwoofer Car Amplifier
If you want something that will give you some headroom, the Audiopipe AP15001D, Hifonics, HFi1000, and the Power AcoustiK STAX or BAMF 2000 1/D are all good budget amps. Set your gains properly though, because it's more power than those subs can handle.
nah, soundigital 16k with the gains turn all the way to the right.
You do know, in the southern hemisphere (Brazil) the gain knobs turn in the opposite direction... like the toilets. Good suggestion otherwise.
Seriously though, SD's have the best technology I've seen... and are actually quite a bargain, if you *need* the power.
Rings? I've had to make them before because the factory speaker mount was plastic, and I've had to make them so the windows would clear the...
137
368
  • Locked
666
Amp
483
zombie616
zombie616
idaho
tinmanchris217
    Jun 1, 2024
    May 31, 2024
