sikramento916 10+ year member
Im gettin 3 fosgate p3 12in subs there 600watt rms n 1200 max...
What kind of amp do i run them with
We all know what a P3 is. Sorry man, there old stuff was good. The T series are ok but not really good. The punch line just *****. Big plastic peice of **** sub.Rockford Fosgate® - P3D4-12
Y I THOUGHT FOSGATES WERE GOOD SUBS
2 Digital Designs 2512Ok this is wat i want.. I want some subs that hit hard but sound real good not a ugly hit that sounds distorted but crisp n where u can feel the floor vibrate out side the car and price is not a problem n what ever box is better and i have a 2000 ford taurusi was thinkin about 3 p3 subs but now idk any suggestions
The guy wanted options. And I would not recommend the Audiopipe for anything. I final got to hear on and my 500 less wattage kicker smoked itas for some cheaper amps, because i dont think everyone has the cash to dump on a fosgate or sundown amp:
MB QUART ONX1.1500D 1500W Mono D Amplifier : ONX11500D : $197.95 : VMInnovations.com
Audiopipe AP15001D 1500W Mono D Amplifier : $149.95 : VMInnovations.com
i personally would choose the mb quart since it's better quality than the AP. both amps will do rated power, albeit the audiopipe won't do it terribly cleanly but if you aren't running it full tilt then you should be fine. if you do decide to buy either of those, use coupon code "CACO85" to save 8.5%
unless it was same subs, same car and same box you can't say your kicker smoked itThe guy wanted options. And I would not recommend the Audiopipe for anything. I final got to hear on and my 500 less wattage kicker smoked it
