what settings do you got and why?
brafferty
idaho
just curious if you guys personally have certain settings you "must have" set for your system? i just went with the standard 120 hz for my door speakers (although lately i kinda like how 150hz sounds) and 80 hz for my subs. the one setting however i must always have set is my tweeter at 6.3kz, because the next step up is 10k and it kinda just overwhelms at that
..... discuss
I usually set the low-pass on my subs around 100hz (which I know is a tad bit high high) and I just fill in by slowly adjusting the speaker high pass while listening to a variety of songs. After that, I turn my subwoofer amp off and just listen to the speakers to make sure they don't sound muddy or stressed by trying to re-create frequencies outside of their response range. After I get the speaker high pass filter dialed in, I hook the amplifier remote turn on back up.
not a bad method, but it ***** when your back speakers are always muddy ;( good thing i never sit back there haha
EDIT: the stars were sux, but i guess you cant say that here
Don't even bother with rear speakers. Front stage is where it's at.
Yes, sucks is censored
it was just on my kenwoods settings under "pro set up", as for where the mids crossover at, im not sure:( i feel dumb now hahaha
Don't feel dumb. Just play around with it and see what sounds best. Everyone likes different sounds anyways.
true but i feel like i should know where mines at, i must learn it all //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
686
The intention of the eq is to create a flat curve if you have peaks and nulls. If you are competing for sq, try to get the sound as flat as...
5
643
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
You are going to need to beef up your sub stage in that vehicle to get that kind of bass response. A good pair of American Bass XFL 10s or 12s or...
4
988
brafferty
brafferty
idaho
big scott
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
