What setup do you recommend for my Toyota Yaris 2019
  • 1
way3000
CarAudio.com Newbie
Hi everybody.
Short story:
I recently got a great deal on a Toyota Yaris 2019 Hybrid H3 GR Sport and I love it, the only problem is, the sound system is made of [insert your most hated material here]
So, basically I want to upgrade, but I do like the stock TAS 500 radio in the car, so what I think is a great idea, is to simply replace the speakers and then put in a high-level input amp in front of the speakers, to maintain a hidden and stock looking install. (sound proofing the doors while having the panels off)
Some good quality speakers/amps should make it so I don't need a dedicated sub? (right?)
My requirements:
I don't want to cut in the original wires if possible, as I can easily solder plugs to make connections so cutting should be avoidable.
I want to be able to adjust the sound settings in the original radio, so just putting a high/low converter in and wire that as input to a normal amp seems like a bad idea? (right?)
I want to keep the stock TAS 500 radio.
Amps should be as small as possible for easy installment, the yaris dosen't have alot of space.
Problem:
So, my problem, I think, comes down to: Is this the best / most correct way to do this, and which amps do I want if so.
Also, do you guys know if it's ok just to tap directly from the battery under the backseat or should some kind of anti-drain system be installed first as it is a hybrid car?
I belive I will go with Pioneer speaker sets as I have had great experience with those in the past.
Sorry for my bad english, and thanks for your help. :)
PS: I'm from Denmark, so the car is european if that makes any difference.
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
575
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
978
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
7
898
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
way3000
CarAudio.com Newbie
way3000
Denmark
way3000
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
