What would you start with for a SQ system if you're building piece-by-piece ?
  • 5
mattsk42
7
SoDak
Basically, I can only get one "set" of things at once. So, a sub+amp, components+amp, or head unit. Right now the car is TOTALLY stock = Double-DIN, 5.25 comp. w/ tweets in A, no sub.
It will be a good 6 months to a year before the next "item", so I figured I'd get the best experience out of (cheap stock junk and a good sub) vs (HU and no sub) or (components and no sub), etc.
Open for suggestions of which of the 3 is best to start with.
ONLY goal is excellent SQ with just barely enough volume to be heard clearly when driving 75mph on a noisy road. No need for SPL at all and no competing at all. My car isn't overly noisy, I just put that there as reference to how NOT loud I would need it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Most people need MUCH more volume than I require.
Open for old skool stuff as well.
Budget is: What can I get for each 1, 2, or 3 to get it fully going for:
1. Less than $750
2. Less than $350
Less than includes tax, shipping, and does not mean = to.
So, like 350 for a sub+box+amp+cabling+whatever to hook it into current HU/system. Or 750 for HU+wiring harness, etc. etc.
What do you have now? If it's all stock I would start with a head unit. Decide what features you need, i.e. Bluetooth, USB, MP3/WMA/WAV etc., if you need to play CDs or DVDs, and so on. If you have a double DIN opening you should also decide if you want a big screen or if a small screen is acceptable in a single DIN format.
You can knock down a good chunk of that outside noise with proper sound deadening products and techniques. I would spend a few hundred dollars on that rather than a few hundred more watts of power.
It's stock now. My car isn't overly noisy, I just put that there as reference to how NOT loud I would need it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Most people need MUCH more volume than I require.
The great thing about using sound deadening is it's like doubling or quadrupling your power, without adding more strain on your charging system. I'm not talking about slapping on a couple of layers of Dynamat. I mean actually blocking exterior noise. Take a look at Sound Deadener Showdown - Your Source for Sound Deadening Products and Information , particularly the CLD tiles, MLV, CCF, and 3M Thinsulate Acoustic products.
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
Not with a Toyota but with a Dodge Stratus. The Security Key Immobilizer Module (SKIM) was activated and it would not energize the coils. Check if...
That's what I'm going to do, cheap, and easy to do. I picked up a spst switch today
I found a solution that you may try. PAC TR-4 Remote Turn on module. It's on Amazon for about $17.00
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
9
mattsk42
mattsk42
SoDak
trumpet
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
