Whats the actual difference in pre out voltage
as I was saying, if you are just trying to annoy your neighbors then it will not be important but it does generally allow you to turn the gain down on the amp, which will result in less hiss. Evry audo system has noise of some kind or another - the question is: can you hear it. Most of the SQ guys went to fiber to break the copper link so there is no ground loop issues between the head unit and the amp/processors in the back.
The difference would be attributed to the QUALITY of the preamp section .. not the actual output voltage. Many people that say they hear a difference in CD players can also be attributed to the analog portion of the D/A, not the digital part itself.
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
itsblown
why is there smoke?
itsblown
Toledo OH
PaulD
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
