whats the difference between the punch 250. and the power punch 250
  • 2
And the 24 db octave HP LP crossover, and the circitry is way better. Thats why you could drop a power amp down to a 2Ohm load with out a problem and not the punch amps.
I have a punch 360 that is not the power series. I ran it at 2ohms for 2 1/2 years straight without a problem. THe power series is a little better quality and a little more power. My 360 was tested at 490 watts according to it's birth record. A power would have given it more like 540 watts. Like fu-man said, better internal circuitry which makes the over all quality and power a little better.
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
Tryin2bump
Tryin2bump
Michigan
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
