SuperScion9000
I don't know what these are called Ik it's for the heat but the actual name. It's an Orion xtr 500.2
Yeah that's mine, and in the trunk of a charger it gets real hot, it was used got 2 amps for 35$ was working fine until I put bigger wattage subs in.FET... field effect transistor I think...
---------- Post added at 12:07 AM ---------- Previous post was at 12:06 AM ----------
That your Crescendo?
Did you have it under 4 ohm bridged?Yeah that's mine, and in the trunk of a charger it gets real hot, it was used got 2 amps for 35$ was working fine until I put bigger wattage subs in.
Yeaah I think soDid you have it under 4 ohm bridged?
Live and learn... LOL!.. that's a 4 ohm bridged/2 ohm stereo amp... I've got something you might like... NOT 1200 watts... but the price IS right...Yeaah I think so
What do you gotLive and learn... LOL!.. that's a 4 ohm bridged/2 ohm stereo amp... I've got something you might like... NOT 1200 watts... but the price IS right...
Tell me the impedance of your subs... I've got a few... you didn't run that Orion at 2 ohm bridged or 1 ohm... did you?.. that amp was not even close to 1 ohm stable even with solid electrical... it's a throwaway...What do you got
Dual 4Tell me the impedance of your subs... I've got a few... you didn't run that Orion at 2 ohm bridged or 1 ohm... did you?.. that amp was not even close to 1 ohm stable even with solid electrical... it's a throwaway...
yup, thats what you called a burned mosfetI don't know what these are called Ik it's for the heat but the actual name. It's an Orion xtr 500.2
With those dual 4 subs it was either at 4 or 1 ohm wired... I'll bet that 1 ohm did it... the heat in the trunk had nothing with the failure... that's a 2 ohm stereo/4 ohm mono ampyup, thats what you called a burned mosfet
i would have to say that i agree. he dunn blewed it up good tho!! Ive never seen a cracked mosfet!With those dual 4 subs it was either at 4 or 1 ohm wired... I'll bet that 1 ohm did it... the heat in the trunk had nothing with the failure... that's a 2 ohm stereo/4 ohm mono amp
