Which 15" sub will be the loudest?
I run knuconceptz wire and have no complaints. I ran that EB flex welding wire. Its good for the price but it is kind of difficult to work with to get it into the right spots you need to but still good wire.
So does anyone have any problems with the Planet Audio BB4000.1? If so can you recommend another amp in a similar price and rms range (Around $300 and 3000rms).
Also can anyone recommend an oscope that is cheap but will help to set the gains safely. I have looked at two different models
JYE DSO112 Pocket Oscilloscope with 2.4" TFT Touch Screen Color Display, Two Clip Probes and Battery included by JYE Tech: Amazon.com: Industrial & Scientific
or
Jinhan Jds2012A Series Handheld Digital Storage Oscilloscope and Digital Multimeter, 20mhz, Single Channel, 200msa/s Sample Rate - - Amazon.com
I would rather buy the cheaper one but i dont know if it will handle the rated power out of the amp.
Any suggestions for a better amp that does a true 3000rms or a quality oscope would be appreciated?
or
That big bang amp is 12lbs... Not awhile lot of beef in there... I'd try n grab on of these Soundstream TA1.3000D Tarantula 3000W Class-D Monoblock Amplifier if you can find one for a decent price. They were like $269
261
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
572
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
605
BSchrowang
Budget Builder
BSchrowang
Peru Illinois
Massive spl
