Which Amp?
The amp will power two sundown sa-8 v2's 4DVC, now should I get the t1000 and wire it down to 2ohms
Assuming u meant the T1000 would be wired at 1ohm with theses dual 4ohm subs the t1000 @1ohm will provide more power than the t1500 @4ohm. That bein said if I had either amp of my choosing Id go with th 1500 with the head room of addin 2 more sa8s also the 1500 will be more efficient running @4ohm vs the t1000 @1ohm.
meh im pretty sure like 90% that those sa 8's will take 1500s(750 each sub) with no problem. those 8s are stout. ive seen up to 1k on 1 8 before and it did fine. just make sure you box is decent
Hey Guys !!! I could use some advice on which amp to purchase . I recently bought 3 kicker cvx 12 subs to install in my galant , also I don't know if matters if factory radio plays a different in sound.
Thanks //content.invisioncic.com/y282845/emoticons/suave.gif.858fc102f7646e678ee8af7e1fbc41d1.gif
T1000bdcp does 1000 at 1 or 2 ohms and 700w at 4 ohms
T1500bdcp does 1500 at 1 or 2 ohms and 1000w at 4 ohms
You'd probably be safe running the T1000 at 1 ohm or the T1500 at 2-4 ohm (due to rise)
run it at 1 ohm t1500 are you set on rockford amps? people here might be able to suggest a little inexpensive amp that will power those sundowns, just throwing it out there
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
252
459
Nav15
Nav15
Arkansas City, KS
Nutdawg651
Decebal
    Jun 10, 2024
