Which set-up? Need opinions!
  • 4
jersyn82
ohio
Ok for those of you that haven't read my recent posts I've bought a second car and I'm moving or building a system in it. I have a little over 4 net cubes to work with. I want to hit the low notes and my question is should I buy a good 15 or 2 12's? (I'd have to to sell my Idmax 10's ) to get 2 quality 12's. My other question is should I go bigger than the Ts 1.8kw I was planning on buying? Remember I only have a 170a mechman alt to work with.
I would personally take an IDMAX 15 over 2 IDMAX 12s. The lows from an IDMAX15 are amazing! 4 cu ft is excellent for a ported enclosure, tuned to 27 hz...it would sound amazing.
whats the budget?
6
148
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
8
629
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
740
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
996
jersyn82
jersyn82
ohio
jersyn82
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
