White noise - is it the recordings?
  • 2
86svo
Hey guys (and gals). So I've recently installed a new setup in my daily and the white noise I hear in a lot of songs is driving me nuts. I rarely listen to the radio anymore since there's more ads than music, so everything is downloaded from iTunes or Google Play. I listen to a combo of classic rock, country and metal and the older the recording, the more I hear the hiss/white noise.
I've bypassed the RCA connections and connected straight to the front channel input of my amp from my mp3 player, same result. I have a solid ground for the head unit and my amps are grounded separate of each other as well. Tried a ground loop isolator, but that just introduced a lot of noise into the system.
Any ideas on this? I have an Lc7i laying around I could try throwing in to clean up the signal..but doubtful that will help. What else could I try out?
Sounds like you have a high noise floor. Gains up high? Otherwise the issue may be with the input section of the amplifier.
I skimmed the manual and did not see any mention of a reset on that model, so bummer if leaving the power disconnected did not help. Maybe Pioneer...
10
4K
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
86svo
86svo
Canton, Ga
86svo
maylar
    Jun 2, 2024
    Jun 1, 2024
