I wired my girlfriends's car some time ago with Knukonceptz 8 Gauge wire, fused 8" from the battery to a small 2 channel amp to power her subwoofer in the trunk. Right now with the 20A or so peak draw from the amp, the 8 gauge is perfectly adequate. I'm looking to add on an addition 4 channel amp that theoretically can draw another 60A, which the combination of the two on a single run of 8Ga wire puts me over the reccomended threshold.
Question: If I keep a 50A-60A fuse on the 8Gauge wire and she is responsible with the volume, will it be ok? Assuming the fuse does not blow. Or should I run a second length of 8 Gauge.
Thanks
Thanks
