Will this setup be good?
  • 1
!.beat killer.!
I have a ported box that is 3 ft long, 17 inches deep, and 13 inches wide. The subs i am planning on using are the soundstream Arachnids that are 12" and 4ohm with 250 rms. the model # is (sw-12se). the amp i think i am going to use is the soundstream picasso 2 channel which has 180 watts x 2 channel on 4 ohms and on 2 ohms it is 270 watts x 2 channels. The amp is a 540 watt rms total. The model # for the amp is (pcx2.540) I am going to use 4 gauge power wire and ground wire for the amp. I dont want nothing extremely loud but i want something that hits good. My trunk in my car gets no air through it unless i open the trunk. my seats dont go down so the subs dont get much air. I was just wondering if this would be a good setup for me. Ive been doing some research and so far i like this setup.. i dont want to put to much money in the system.
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
587
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
990
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
7
907
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
!.beat killer.!
!.beat killer.!
sardis city al
!.beat killer.!
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
