Wiring 6 Wire Harness to 8 Wire Harness
  • 2
Im wondering if I can split the black wire on each side of the old unit (6 wire) into 2 wires. Then splice the 2 new ends into the positives on each side.
For example, on the left side I would splice as follows
6 wire / 8 wire
Green to White
Black(end 1) to White w. Black Stripe
Yellow to Green
Black(end 2) to Green w. Black Stripe
Does this make sense? Can the black wire on each side of the 6 wire harness be split into two, essentially making it an 8 wire harness?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
you have to have a pair of wires runnin to each speaker. are running those is series now. you can find the wire that runs from the front speaker to the back speaker you could cut and splice you wires there. otherwise you might have to rewire.
---------- Post added at 02:32 PM ---------- Previous post was at 02:31 PM ----------
6 wire / 8 wire
Green to White
Yellow to Green
dont do this
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
121
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
189
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
404
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
376
motown83
motown83
MI
CrossoverOre
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
