Wiring powered Subs through Amp-
35WINDOW
I have asked this question once before and am still confused (sorry!)-
A little background-I am building a high horsepower Hot Rod (800+ h.p.)-it is a 30's Ford Coupe, so inside space is at a premium (read: small)-through this debacle I have purchased 12" Subs, 10" Subs and now, 2 Infinity Basslink SM's (8') (yes, I know you guys don't care for Infinity, but they had what I wanted)-
So-this is powered through a Infinity Kappa K5 Amp (I wanted it to be Bluetooth), and thought I had it made (at first), which is why I bought the 12' Subs-found out there was NO way to fit them-same with the 10", so I bought the Basslink SM's (they barely fit under my Seat)-it's really not what I wanted, but they are all that will fit, so-
My problem is wiring them-my Kappa K5 is a 5 Channel Amp, so I have to split the signal (I thought when I bought it that I would only have one Sub, but.......)-
So, my confusion comes from:
1. Knowing which input to use (line level-which there are 4 connections-I only have 2 input wires, + & -), or speaker level (RCA, of which there are two connections; see Owner's Manual (hopefully the Link is correct):
https://pdf.crutchfieldonline.com/ImageBank/v20151103104200/Manuals/108/108BASSLSM.PDF
2. If I use the RCA Jacks (I've purchased everything needed to do this), obviously, the Sub input only has a plus (+) and a minus (-), but the RCA Jacks have an added ground-how to use that (as there wouldn't be an actual "ground" with only two inputs?
I've tried to attached a drawing how I think it would be wired with RCA Jacks, but the File is too big to share-
Please help! I've built a $100,000 Car (and understand electrical pretty much), but this totally confuses me-
Here is a copy (hopefully) of the Amp Owner's Manual:
https://pdf.crutchfieldonline.com/ImageBank/v20160511134700/Manuals/108/108K4.PDF
Thanks in advance for any help offered!!
The Sakr OFC wire is as good as any other for that price for sure, not talking about their amplifiers. If you have enough, dual 12 gauge runs are...
92
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
179
394
369
35WINDOW
35WINDOW
Whirrled Peas
garychoffmann
    May 19, 2024
    May 19, 2024
