Wiring the audiopipe apd3000d to two dual four ohm subs
what do you want? 1 ohm? or 2? im pretty sure you cant get two out of dual 4's, but if you wire the subs in parallel, then parallel together, that will make 1 ohm. get duals 2's to get a final load of 2 ohms. audiopipes should be 1ohm stable.
The AP3000D is only stable down to 2 ohm. The 1500D will do 1ohm. FYI, the 3000D is just 2 1500Ds strapped inside one case.
in which case the OP has to wire in series and present amp with a final 4ohm load
and no, you cant get 2 out of 2 4ohm dvcs on a mono amp. You can on a 2channel tho by wiring a 2ohm stereo load
this....dont take advice from
wait a minute, that amp is 1 ohm stable....only with 2 channel though right.......
2 channel = 1500w at 1 ohms
1 channel = 3000w at 2 ohms
correct me if im wrong but couldn't the OP just wire EACH sub at 2 ohms and go 2 cannel...he would probably get around 1000w to each sub
2 channel = 1000w? at 2 ohms
326
328
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
584
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
446
ken2516
ken2516
albany ga
Deeper_shades
    May 12, 2024
Brendon Jenness
    May 11, 2024
