Wiring two subs
  • 3
Those amps are 330w RMS x 1 @ 4ohms. (and 600wRMS x 1 @ 2 ohms) So unless you already have these sitting in your closet, and those subs are 250-300w RMS @ 4ohms each, (or 600w rms @ 2ohm) I wouldn't. I wouldn't buy two amps to do this when you could just run one amp, and a little more speaker wire.
If they are both 4 ohm, then an amp that will double there RMS @ 2 ohm is a better option.
If they are both 2 ohm, then an amp that will double there RMS @ 1 ohm is a better option.
Thank you
WilliamK#24
CarAudio.com Newbie
WilliamK#24
Three Forks Montana
audiobaun
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
