wiring won't work
Headunit?
Check the ground, I know when I had a faulty ground, the amps will power up for like 5-10 sec, and then die.
what are you running the amps, is it a 4-channel or sub, whats the ohm load your running at, whats the wire size and the current draw?
answer these question and i can give you an answer on what your problem is
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
412
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
486
547
488
Pitbull2o08
Pitbull2o08
Youngstown, OH
blackbonnie
    Jun 1, 2024
    May 31, 2024
