Hey i have a Sony X-plod Class D 1000 watt amp...
and I have no idea what kind of woffers to get...
If any one can give me a few suggestions it would be really helpful
The amp can take up to a 4 om Load.. i think ( correct me if im wrong)
these are the Specs
Frequency Response -- 5-300Hz (+0/-3dB)
Harmonic Distortion -- 0.06% or less at 1kHz, 4 ohms
Speaker Impedance -- 1 - 8 ohms
Input level adjustment range -- 0.2 - 6.0 Volts (line level), 0.4 - 12.0 Volts (speaker level)
Power Supply Voltage -- 10.5 - 16 Volts
Current Drain -- At rated output: 40 Amps at 4 ohms, remote input 2.0 mA
I need some real thump... If possible feel the bass if im standing out side the car...
I have 200$$ to spend on the woffers... so if you have any suggestions please let me know
ThnX
these are the Specs
ThnX
