Would the signal from amp pre-out be better than LOC signal?
  • 2
BTF
CarAudio.com Newbie
23
Oklahoma
As the title says, which would give my sub amp a cleaner signal? Currently using a LOC for sub amp signal, but thinking of getting an amp for front speakers, and one option has pre-outs, which I could use to send the signal to the sub amp. But would it matter? TIA!
You don't need two LOCs unless you want to separate the fader. Pre-outs should be roughly equal in signal strength to the original cable. It's the same thing as a y splitter just that it happens inside of the amp.
Actually, I was wondering if it would make a difference running from speaker wires > LOC > both amps - VS - speaker wires > LOC > front amp with pre-out > sub amp? In other words, will the pre-outs give the sub amp any better quality signal than the LOC?
No, there's no processing done on them, it's literally just a short between the pre-outs and the rca inputs. All it does is prevents you from needing a y-splitter RCA adapter and the connections inside the amp are probably of higher quality and thus lower resistance than your typical cheap y-splitter can manage.
Okay, thanks!
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
u may be referring to the yellow wire and red wire. But there's a voltage drop just at the on position. So no signals come in via antenna. Or...
Yeah but accubass only restores the bass roll off. It doesn't take an incomplete signal range and make it a full range signal.
13
If this amplifier is an aftermarket unit, it should have RCA Output. If it is not, then connect to the rear amplified speakers. The sub amplier...
BTF
CarAudio.com Newbie
BTF
Oklahoma
BTF
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
