Would these subs work well with amp?
  • 4
why dont you tell us what you want, bass wise, youre budget and how much room you can give up for sub box. we can recommend gear from there
what vehicle too?
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
kylemarsound
CarAudio.com Newbie
kylemarsound
nauc
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
