WTF is going on?
  • 2
™Caveman
SoCal
Installed a sax1200d yesterday. It played awesome all day until a late night cravng at jack in the crack. While playing radio at low levels the amp shuts down. DMM shows 14 volts from remote but only 6 volts from battery. No fuses blown or anything... please lend a brotha a hand here.
You probably have a loose connection somewhere. Is it a steady 6V, or does it seem to jump? Also, make sure you test up front too, to eliminate the rest of your vehicle as a problem.
I'll tighten it up just in case anyone else chiming in?
---------- Post added at 10:42 AM ---------- Previous post was at 10:42 AM ----------
Steady 6
I mean check all your connections. Don't know if you just typed weird, but which did you mean when you said tightin IT (singular) up?
thanks bro problem solved. Fuse was blown under the hood although not visually ...weird...
As title. Once i get to about 4/5 max volume my JL HD600/4 amp goes into protection mode on 2 channels, powering my mids. The other 2 channels...
maybe bad amps. I would purchase a decent amp off of Amazon. They usually arrive in 2 days if you have "Prime." If the problem persists, you can...
11
Now you're annoying me because you are attacking me personally without addressing anything I've said. Show me a single post I've made that's...
20
4K
™Caveman
™Caveman
SoCal
™Caveman
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
