Xmax/Excursion. What subs have the most?
So when RE says the XXX has 54mm, are they referring to 54mm one way!? Is there any production sub that has more then a 07+ XXX?
Yea I ran an HCCA 12 and that think was a monster! You really gotta be prepared to deal with that thing. I was giving it 1800 RMS, and it was not even close to enough, (not to mention my stock electrical *****!). And of course, my box was no where near strong enough. But all-in-all, one of the best SPL subs out there.
Probably one of the best SQL subs out there would have been a more accurate statment , Great subs , but would like to have more top and bottom plate and more motor force in a SPL sub.
I'm pretty sure the BL^2/RE is around 150 - 175 depending on what VC's you have on the HCCA's
Probably one of the best SQL subs out there would have been a more accurate statment , Great subs , but would like to have more top and bottom plate and more motor force in a SPL sub.I'm pretty sure the BL^2/RE is around 150 - 175 depending on what VC's you have on the HCCA's
Well I dont know a whole lot about parameters, sorry. But I do know that it was one of the worst SQ-Wise subs I have ever heard. Had nothing to do with the music, just all about being loud.
what box did you have it in? tuning/etc? SQ is more than just the sub =P
Had it sealed up, in the box Orion recommended, cant recall the size, maybe 1.7 cubes. I know the box wasnt built up to its weight, (to be honest), and I could have given it much more power, but it still wasnt very clean at all...
1) That is correct. I bought mine from Amazon. Those were the actual links I used to purchase it. If you're budget conscious I'm sure you could...
They're rated for 250wrms, so you were overpowering them, especially the poor 10s. XBL subs sound really clean at their limits due to the flat BL...
10
312
453
16
boomzabit
boomzabit
Minnesota
Deiimos
    Jun 1, 2024
    May 31, 2024
