xs power d3100 vs kinetic hc 2400 or hc 3800 vs shuriken bt 120 vs batcap 4000
  • 3
the sig has all my electrical info and im planning to upgrade to the new aq 3500d.1 and a t600.4... which battery is the best?...and is kinetic still around? thank you
Yes Kinetik is still around, they had many dozens of cars using them at both SEMA and CES. They are also used in an upcoming issue of Street Trucks.
SEMA: Not Your Typical Trucks and SUVs - MSN Autos This Navi was on the home page of MSN for a while during the show this past November
Kinetik is also at all the major car shows across the country.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
495
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
711
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
522
Matt A
Matt A
Youngstown, Ohio
Matt A
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
