amp protection help
Hunter 4456
19
Hi I am searching for help with me amp the set up I have is 5 woffers with 3 amps I have a new battery and a brand new 220 amp alternator ran back with 0 gauge wire to a 4000w rms capacitor then I have a 12 ran to 1 amp and 2 10s ran to another and finally the problem child I have 2 15s ran to an am the 2 15s are 600rms each dvc the amp I have them wired to is rated at 1000w at1 ohm witch is what I have the 2 subs wired down to all the other amps work as they should and have no problems but this one amp keeps going into protect just after half volume it will hit 3 or 4 times just before it goes out but works as it should at low volume any help would be appreciated! Thanks !
Well I can't help you anyway. I only run 1 sub at a time maybe 2 of the same size and model #. Just a little guy. I wouldn't know were to begin. I was just curious about it.
 Someone will probably help ya out sometime today.
Ok thank you, I'll check where the remote wire is connected and get back to you.
Ill try it when I get the amp back, especially if the forbidden protect light goes on. I don't think it's grounding out anywhere because I still...
Make it look nicer. Carpet it up with black. It will look like a speaker. The wood look is not good at all. Don't look too professional. What...
39
6K
Disconnect all 5 speakers and the rca cables from the amplifier. Turn it on and see if it still goes into protect. If it does, bad amplifier. If...
Not much user serviceable about an amp powering up into protect with nothing else connected. Send it back for repair/exchange or whatever they do...
Hunter 4456
Hunter 4456
fithwheel
