Help with my enclosure
Lol this dude is back? Hahahah  Already had to put one thing he said in my sig.
I think he's gonna be the champ someday... he just won't quit
You guys should just ignore everything this nutsack says and let him figure it out on his own since he knows more than everyone with all these genius ideas. People like this deserve zero help.
But its fun to roast him...maybe he'll get it... but he better watch out for those unwanted (coil burning) frequencies...  :ban:
ok, i figured out, that bass réflex opposite to woofers, is a bad Idea. that's why I was thinking about flip everything, and put a vent at the same side as the woofers, and fire everything into the Little hole that sepparates cabin from trunk.
but the réflex if its in the middle, it will fire in to the cabin, the rest will bounce back at the seats.
so the vent would end up like good (a), but the woofers will end up like bad (a)
thanks
On ‎3‎/‎8‎/‎2019 at 8:15 PM, Popwarhomie said:
bro, you can't compare top end sundown, to the lowest end MTX. you have 3 times the excursión in any sundown.
the designed liters for my MTX is 50liter for sealed and 70liters for ported.
so, in a 4th order, I immagine I need around 120liters, right?
you need a box as big as the one in that video. IF you cant do that, then forget it.
how does a 4th order sounds like??? a restricted band sealed box, or a bass réflex?? you know what I mean, that dry punch of sealed, or that longer muddy punch of bass réflex?
I used BASS Box Pro. It’s what parts express uses on most all their woofer spec recommends. I didn’t build the box phisically that is. I also...
Just remember when you pick a tuning frequency as you go higher the box gains efficiency, but loses low end and tends to become peaky.
Here’s another idea I was thinking of. I’m doing a single 12 in the center of the box just for aesthetics I was wanting ports on the sides of the...
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
XxAndreaxX
spain
fithwheel
vlusardi
    Apr 27, 2024
    Apr 27, 2024
