Help with my enclosure
I bought some wavecore speakers from parts express. Despite being manufactured in China they're well built.  They have some nice looking drivers and tweeters made specifically for car audio too. More on the sq side of things
Built a desk for the old lady too  now maybe I can finally get back to building some enclosures
Everyone has tried to help you. You just wont listen....
A 4th order for a f*****g 15" is going to take up your whole trunk.
A 6th order for a 15" is going to take up the whole truck and a half.
A T line for a 15" is going to take up the whole car.
Get rid of that garbage subwoofer. Buy a nice 12" and build a proper ported box...
yeees, you tell me to buy a 12" and build a ported box, I can't because i get cancellation! seems like it has to be at least 4th order to make any sense!! that's why i put isobaric in equation. if isobaric halfens the volume of the enclosure, maybe I can get a decent size enclosure for my needs. a normal 12" would also eat up the whole trunk if the layout is 4th order.
maybe I made an error to buy 2x 15", but maybe there's a way to fix it without throwing everything away
Thats right. Ski hole. Got confused with all the retarded post on here lately.
Do a 12" in a 2:1 or 3:1 ratio 4th if you can fit it.
Thats right. Ski hole. Got confused with all the retarded on here post lately.
ok 3:1 ratio you mean ported 3 and sealed 1 right?? what would be the difference if I thorw in an isobaric 15" instead of 12"??
wouldn't I gain a Little bit on space??
O M F G....   Done....
bro, for you its everything obvious, for me not because I don't have a clue. I tried to study the whole topic, and I read everywhere that isobaric needs half the space than 1 normal driver. is that true?? if its true, would the 4th order of a doublé isobaric 15" be smaller than a single 12"??
There are many "Isobaric" designs. Still would be a massive box with 15s though.
If you are talking about a sealed box with a two 15s push/pull that is pretty much pointless since you are getting cancelation being confined to the truck with seats that don't fold down.
4th order with a 12" or 6th order with a 10" would be my answer.
I think you should get a 5 gallon plastic bucket with lid and put your sub in that, if you want it ported duct tape 2 3" pvc pics on the outside for maximum dbz
still massive?? 😢
on oficial MTX spec sheet of my subs, it says 50liter for sealed and 70liter for ported. is this also wrong?? 70liter is a relative small enclosure, and if isobaric, should be 35liter thats a mini box.
so if I do a 4th order 70+50liter isobaric, it gives 35+25 liters.
is this a plausible calculation, or is this totally wrong??
what should be a right calculation instead??
what could be a volume for a 12"
a volume for a 15"
a volume for isobaric 15"
must not be exact, but to have an idea at least
As many days as this thread has gone on you could have downloaded a free software program called Winisd watched a couple of free you tube videos on how to use it and used your own judgment on rather or not isobaric or whatever type of enclosure design is worth doing for whatever subs.
New Idea, maybe the easiest and cheapest solution
a normal isobaric bass réflex, with an added slot, that bends both woofer and port directly into the cabin.
is this an option??
I go back to read this idiot thread from time to time just for entertainment.... I suppose other noobs are frustrating but this guy took the prize.
I wonder if he actually followed advice and got it straightened out.
I used BASS Box Pro. It’s what parts express uses on most all their woofer spec recommends. I didn’t build the box phisically that is. I also...
Just remember when you pick a tuning frequency as you go higher the box gains efficiency, but loses low end and tends to become peaky.
Here’s another idea I was thinking of. I’m doing a single 12 in the center of the box just for aesthetics I was wanting ports on the sides of the...
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
XxAndreaxX
spain
fithwheel
    May 10, 2024
3toneEYZ
    May 10, 2024
