Big3 upgrade problems
Rockville amps are cheap POS amps (boat anchors) not really meant for .5, and if your clipping the current draw the amp wants will get worse. Cheaping out on an amp can work sometimes but trying to surpass your electrical capabilities causes issues every time.
Ik they aren’t good😂 was just something cheap to get till I upgrade. I’m just trying to get electrical worked out before I get my next setup. Going for taramps 1800.1 and 2 sundown s-12s or 15s in a custom box.
I've had a couple of their 4 channels. For $99 they weren't bad at all. Got very hot though as the heatsink design was pretty bad.
18435
What subwoofers do you have. You need a mono block amp for subwoofers. Not a 4 channel.
Yes I know, I said earlier that I was gonna upgrade everything and what I was planing on doing. But I’m getting a taramps 1800.1 and most likely 2 sundown sa-12. Not for sure on the subs yet bc I’m looking for something a little cheaper but most likely those.
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
493
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
608
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Are you planning on upgrading the alternator and add extra batteries?
791
Prestondrew40
Car audio enthusiast
Prestondrew40
Mobile
Jeffdachef
    May 22, 2024
    May 22, 2024
