Transfering 6.5's into 6x9's
fromhailey
My car was totaled and I removed my stereo system to install into the new car. The set up is 4 6.5's, dual 12" sub, 5 channel amp, double din reciever. The car I want to buy is a Toyota Camry with stock setup of 4 6x9's and 2 tweeters. I have read that it is possible to put a 6.5 speaker in to replace the 6x9, with special mounting and adapter. I will have the installation done professionally, but they are closed due to 'stay-at--home" order, and i would like to get some answers now rather than wait (to help my car purchase decision). Do professional installers do modifications like this (like CarToys)? How many other peices of the system does it effect? For example, does this require special wiring, or is there a component I'm unaware of. How much extra is this cost besides what it would already cost to install?
They make speaker adapter plates to go from 6x9 to 6.5. Generally they run around $25-$35 a pair. The shop I work charges for adapter plates but no extra on install. I would recommend some dynamat for each pair to ensure that things get sealed properly. You don’t want air leaking between front and rear of speaker.
It does not require any additional wiring. As previously stated in prior responses, they use adapter plates. It does not affect any other part of the system. During a DIY install, I also made my own out of cutting boards. I installed 6.5" into a round 8" opening.
I 3D printed my 6x8 to 6.5 adapters for my Escape. Cost about .60 to make each x4=$2.40 and a couple of hours while I was doing someone...err...something, else. ;)
I have an extra pair of these, NIB, $100 shipped!
14
Excellent!! Looks to be in tact. It will be a workhorse for you man
40
5K
Might be time to try something new as it sounds like it is the limitaion of the speakers. I’m not in the habit of recommending JBL but a buddy of...
40
5K
This is still a very nice Deal package for an entry level amp set up for some quality amps for the money...
18
If the JLs are not entry level, then do not torture yourself, just go for it. You already enjoyed those DS18s. In case you do not like them, the...
fromhailey
fromhailey
Wahington
Squirrel!
