Best JL Audio Sub Pairing
Thanks everyone for the pointers. Update: I’ve settle on the 10w6. It’s actually the HO110-W6v3. Sounds great with jx500/1d. The amp is rated at 500 watts in 2 ohms and the sub is 600 rms at 2 ohms. Now aiming to upgrade to the jx1000/1d. Thanks again!
1000W will destroy that W6 very quickly.
So, should I just keep the jx500/1d? Is it even worth upgrading to meet the 600 rms?
jl is very underrated they usually put out more than what they say and the subs can handle more than what they say, i personally would think its a good move if ur trynna get the 1000/1 but jus b cautious about the coil smell and the distortion, jus keep it at prolly 1/4 - 1/2 of the way up on the gain
Looks like he has the High Output box from JL. I’ve heard really good things about the boxes. If you do upgrade the amp, don’t get the JX. If you have to stay JL, at least get the JD but I would lean towards the RD as is has a very useful clip indicator while your setting it up (newbie proof kinda).
Interpreting your question as "what's the cheapest SQ head unit" the answer is: Pioneer DEH 80 PRS. That's sort of the most famous "entry level SQ...
I'm running those in my pickup. There's no real "best amp" answer. You want something with really low THD, and 100-150w RMS per channel.
Stream? Unlikely https://www.smsl-audio.com/portal/product/detail/id/809.html https://helmaudio.com/products/boltdac You might can stream in...
Pumpkins1977
Junior Member
Pumpkins1977
Chicago, Il
Clifff150
    May 31, 2024
    May 24, 2024
