Subwoofer turns off! Plz help!!!
Scary_boy_dave
17
Michigan
I have a rocksford Fosgate 1200x1 amp with 2 p300 subwoofers and when I turn the bass boost up on my stock head unit sometimes the subs will turn off. They don’t just stop working but they will just turn off for like half a second and idk what’s going on. And the “clean” input and output lights don’t blink. (It’s all installed in a Pontiac g8)
OP, if your subs didn't turn off, you probably would have blown them by now. They are going into some kind of overload protect, the amp is. You're almost certainly exceeding the limits of your equipment by adding the bass boost. There's only so much bass your system is going to safely output.
My subs are quiet for being p300s normally tho. I’ve heard a single p300 and my system should be quite a bit louder.
Well, what wiring do you have, what kind of box do you have, where's the box located in the vehicle, there's a lot of factors into what makes a system loud.
i have the rocksford fosgate specific 100amps wiring kit. and its the p3 loaded enclosure made by rocksford fosgate. and its all in my trunk (its a pretty big trunk).
Amplifier comes into as well. How many watts are running into them and at what ohm? Buck has it completely right. Also just because the box was made by Rockford Fosgate doesn't make it correct for all music or the music you listen to. A properly built box with the correct tuning and size requirements makes a difference vs a stock box they sell you that is a setup for "general" purposes.
i have a 1200 watt mono block amp at 1ohm. its the r2 1200x1.
What are the subwoofers wired for? What are their ohms? As if they are running at 4 ohms or 2 ohms then they won't be getting all of that wattage. I am betting a proper box built to what kind of music you listen to for your vehicle would make a world of a difference. @Buck does designs for custom boxes every day all day long. He sends you the designs based on what you listen to, the subwoofer make/model and for the room you have available.
I have no idea what the specs are on the RF loaded enclosure(s). Um, hmmm.....it almost sounds to me like you just need a bigger system overall. If you want louder, I think that's the way you gotta go, or settle for about the same loudness you have. You could try to build a custom box, iirc RF recommends decently high tuning, I haven't looked in a while though. Their boxes might be at something like 38 hz. But it seems to me like you've gotten normalized to your bass, you may want to consider upgrading. Custom boxes are really like the most important part of sub system, if the box isn't good, nothing is going to be good, no matter how much money in equipment you have. So just some things to think about.
Also those P3's crave power. I have one in a 10" Dual 2ohm version and 1,000 watts to it just wasn't enough.
Edit: They claim 600 watts RMS and 1200 peak but go by the RMS.
I am kinda leaning towards what ohms are they running at and wired inside the box at this point. I know those P3's can get down when setup right.
Also what size P3's are those? Unless I missed that part in the thread.
IF this is the box they claim its wired to 1 ohm. Only 5/8" MDF though bleh and nothing on the HZ for the box either.
This is what they say the box size is. They say for ported the box should be 1.79 cubic feet per subwoofer.
Dimensions
Box (H x W x D)
Wedge (H x W x D1 x D2)
15.125" x 33.875" x 15.75"
yes that is what i have the 2 12 inch p3s the are wired for 1ohm.
Box is doodoo. For sure
Maybe your amp gain is set too high, or wasn't set properly with the head units volume adjusted properly prior to setting the gain since you...
544
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Scary_boy_dave
Scary_boy_dave
Michigan
Scary_boy_dave
    May 18, 2024
    May 18, 2024
