1998 chevy suburban 2500 high output alternator
Apolloneeeeek
Vegas
Hey guys im new here and am trying to get into higher output amps and subs and wanted to see if anyone has a recommendation for a high output alternator for my truck i have a 2 wire 124 amp alt right now and know its not enough for jack **** lol. Thanks again.
https://www.mechman.com/320-amp-high-output-alternator-gmc-chevy-yukon-
https://www.mechman.com/alternators...mp-elite-series-cast-alternator-for-gm-truck/
The company DC alternators for the 5.7L suburban (which I believe is yours) only has the 370A model which is expensive.
Singer alternator is a good choice but since it's a 1 man operation you have to email him directly and patiently wait for a quote. His alts are made specifically for car audio https://www.singeralternators.com/ (messaging him on facebook is probably faster as well)
Ok great i will try for singer. I should have mentioned I have the l29 454 motor and its a k2500. Singer seems like he can take all this into account vs the other options being 1 size fits all
Also could you possibly recommend a company or battery for more juice to power it ive been looking at either agm or lithium.
Singer is great (i've ran 2 of his alts with no issues). The mechman I posted list the 7.4L sierra as working with it so yours should since it's the same engine (7.4L L29 454).
When they list that a specific alternator works for a ton of different cars it's not them just guessing, it means GMC/Chevy used simliar mounting/casing for all of those models intentionally
Batties Plus which is brick n motar has multiple locations in Vegas. There X2Power series batteries they sell are re-badged NorthStar AGM batteries which are super high quality.
Awesome thanks again man. Ill be coming back when i get those two set up for more questions about my headunit amp and door speakers. Appreciate it again.
Check into JS Alternators, Brand X, Ohio Generator, Mechman, Singer, those are all good legit brands that will have an alt for your application. XS Power is a battery Co. They don't sell alts, per say. But are kinda partnered up with Mechman ....
Well over a year old post...
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
969
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
676
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
Apolloneeeeek
Apolloneeeeek
Vegas
KicktheSDbasshead
    May 19, 2024
    May 19, 2024
