Subwoofer Recommendation
I take my bass up to a soft clip on every demo that I give. I had to replace my back window and the new glass flexes like crazy. My thinks that is how I lost 1 db on the meter. 🤷‍♂️
I sealed my back area off with Foam insulation and 2x4s and 3/4" plywood so far with 3 layers of 80 mill. Closed that up. Ive never Metered. Ive had a couple cheap meters that went up to 140 and went into error every time is about all Ive done
Not at all. Just enjoying the Conversation from one Bass Head to another at the Music Liking Freq. that most do not get to experience
I'm probably tuned a little too high to really compete. It get's windy for 4 - 8's. I've competed three times. Two firsts and one second. I'm usually the only one with 8's and I usually meter lower than all of the big systems. They don't believe that I peak @ 31 hz. until I run a sweep.
What setup, vehicle, and power?
Truck in my sig. 98 x-cab Chevy with 4 -1st Gen XFL 12s in 2.0 @32 HTZ per chamber,on Two A.Bass 1st Gen. VFL 4480.1 and One 1504 Hybrids, CDT Brax. 6.5s with upstage ES200US Xovers with DRT25 tweets in doors, A-Pillar and Kicker KS25 tweets and another set of CDT tweetson Autotek Mean Machine 44HC,CDT ES-06 mids on Mean Machine 99(Took the BTX 7204 Out).Eclipse CD3000 and swapped with Kenwood BT955HD, Kicker KQ9 EQ and swapped at times with an E.Quake EQ7000,6 Orileys 34/78 Super Start AGMs,Built 300 HO Alter Starts Alt. 2-0 Ga runs and Big3 x2 under hood 4 agms in rear.Stinger Pro Distro Blocks and Scroll fans
@audiobaun, I meant meter at a lower frequency. The XFL's are the new VFL's, right?
I have 4 of the 1st Generation 12 DVC4 XFLs I want to use. I have 2 -1st Generation XFL 10s also.. 2-Newer XFL 12s of both DVC4 and 2ohm and 10s also, 4- old School Audiobawn AW 1008Ts, Aw1006Ts, 4-S.Qubed older HD310s, 312s, 210s, 312s,, Several AB subs in 10s and couple 12s, Audio Techn. 12s, Dayton HO 10s,a few others. ect. I have a couple more in my Audio Rm. Amps , Speakers, Xovers HUs. ect.
Didnt mean to Blow your Thread up OP. My Apologies. Ill keep in on Subject man. XFLs are worth every penny. Cant go wrong with either brand of sub mentioned. Just need that tuned Enclosure built properly to make it all happen and some decent power. Though Space needed and Location is key as well as to port location also. Several factors come into play.
Guys I need help, lol. I am upgrading from my AB xd10. I have a sundown sfb 600 amp which will run up to 1000w dynamic. I am looking at the AB xfl, AB Hawk and the Sundown Sa Classic. All subs are 2ohm dvc subs. I have a 1.25cf ported enclosure tuned to 38hz. Which one would you guys go with? Not looking for a pissing contest or versus here, just what you have ran and why you like it. If my amp will not support these subs adequately please advise on that as well. I am looking for a good daily that hits hard, thanks in advance.
Please look at the VFL 10's. They are near impossible to beat for the price. I heard one in a Honda CRV and it was doin work.
404
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
Grimmjoww
Grimmjoww
Tennessee
Grimmjoww
    May 8, 2024
    May 8, 2024
