Second battery or no?
JmOnEy69XyZ
The amp I am running now makes my lights flicker in the dark. Do I need to run a separate amp to my CRT 12 & 15 and leave the main amp on the Solobaric 15?
Oh Boy! First off you need to be running two of the same subs and same size subs. But hey if it works for you then bass on. You need to upgrade your electrical. Do some research on the Big 3 upgrade. Get the biggest AGM battery that you can fit under your hood. Then you should be good to go.
Start with the Big 3,and the largest AGM you can cram under the hood as @ Bobbytwonames has recommended. If voltage is still an issue, a second battery or H.O. Alt. may be needed to satisfy the demand
What amp is that?
I'd guess that if you threw all that other **** away and just build a good big box for that square sub you would get louder and sound better. Mixing and matching subwoofers is almost always going to give poor results as is using prefab boxes.
I have a 2018 f150, looking to keep factory head unit, not running a dsp as this is budget build. I have a t harness, skar doors, amp and subs...
So, why the fukk is the pedo replying to me? He started the shitt again and I am responding. What don't you understand?
75
8K
JmOnEy69XyZ
JmOnEy69XyZ
Indian Trail, NC
Bobbytwonames
    May 12, 2024
    May 11, 2024
