Bluetooth home stereo build
SlugButter
CarAudio.com VIP
4,664
2,146
arizona
i liked the other one so much I decided to make another for my TV/video game room. 1 tang band 6.5 inch sub ported. .35 cubes tuned to 38 HZ. 2 Viston 4 inch coaxials. Subwoofer is low pass crossed at 150HZ. Coaxials high pass crossed at 150 Hz. Power supply is 24 volts 6.5 amps. Amplifier is a 2.1 channel 50 watts rms x1 for the sub. 25 watts rms x 2 for the coaxials. Amplifier has adjustments for low pass filter, sub level control, speaker level control, treble attenuation and master volume. Will also be adding rca connections for accessories. Using 1/2 inch scrap wood from the trash bin.
Also using various diameter aluminum rod from the scrap bin for the protection grill. 2 1/2 inch. 2 3/8 inch and 4 1/4 inch bars. All cut to 7 inches because that was the longest one in the trash. Times are going to get rough. Trash is useful.
View attachment 39058View attachment 39059View attachment 39060
I am looking to build a bluetooth boombox for my shop from old car audio stuff that I have kicking around, I've been trying to find a good instructional article or video with a list of materials and walkthrough of how to build. Does anyone know where I can find?
power supply, amplifier with BT connectivity and some speakers is about all you need. Maybe a couple of crossovers
Sounds very nice. The front firing port style I had was a little louder, but this one sounds better. Will finish the grill tomorrow. Plan didn’t work so I will buy the aluminum bars tomorrow.
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
630
There is a good chance you could add some sort of Bluetooth or AUX input to a vintage stereo such as a 1978 Pioneer, maybe with a separate toggle...
690
A problem may be caused by your phone's or vehicle infotainment systems' software. Be sure you have the latest software version for your phone and...
I recently bought this exact bt adapter for a cda9813 and it works flawlessly
871
SlugButter
CarAudio.com VIP
SlugButter
arizona
SlugButter
    May 16, 2024
    May 16, 2024
