12 inch sub options
Jimg
217
13
Air space 1.5. - 2.0 cubic feet
amp. 1500 wat US acoustic Mike
2010 camaro
I know it is not ideal but would like to pping the sub and port into the cabin of the car, I like to have the amps and all the wiring on an amp rack in the trunk
currently Have two 10 inch Dayton HO 10,s They sound ok but not as much output as I would like.
what 12 inch would work well with 1500 watts and the Space I have to use
2010 camaro
Budget? I would suggest that you run two VFL 10's or SA 10's in that same box. You need the cone area. Buy two D4 subs and run everything @ 1 ohm.
Thats a good looking sub. Ive book marked that site. I may try one out for an Xmas present to myself??
50
6K
Yeah I’m up ****’s creek. OP has gotta be more specific about his equipment and what he wants, IMO. 10’s take different boxes, so it’s hard to...
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
This. It's hard to beat for the money. They can take a pounding. Make sure that your amp is one ohm stable. If it isn't the buy the dual 4 ohm sub...
Jimg
Jimg
E9 Industries
    May 19, 2024
    May 19, 2024
