AMP suggestions
  • 5
Name'sDEEZ
121
15
Earth
Im looking for amp suggestions for a daily i currently have 2 12 pioneer subs that handle 1000watts peak so 500 rms each and the amp i thought that would be ok to drive em until i saved enough doug is starting to make me regret it. I thought it was a good brand. Its a hifonics zdx-1000.4 (cant even find a manual that tells me the power ratings)
So whats the best amp at a minimum budget? ill also include pics of local sellers with what they offer maybe one of them could be decent enough. Big thanks in advance.
I'd steer clear of all those...if $129 is in your budget...this one will make rated power...
99.99% of these amps are listed are Low tier over rated Flea Market amps
Do you have a Link of the Pioneer subs you have?
Sorry like i said the tag fell off. Theyre oldies but somehow have still survived multiple cars.
You could take a DMM and Check to see what each coil reads of Ohm value. By looking and assuming as old as it is possibly a SVC4 or a DVC4? Have see back side to see if it has one or two wire connects and check each coil to see what they read.
What is the model of the Pioneer Subs?Whats your budget?
Hey guys off topic if an amp says it does 500w×2 at 4ohms can i just use one of those 2 channels to get the subs to what the amps likes?
CT Sounds amplifiers are on sale as well. Might take a look at these
Yea ct sounds are $$$
751
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
784
Hi guys, I’m John. Been out of car audio for probably 15 years or so. I built a couple boxes back in the day and was definitely a bass head but...
144
374
Name'sDEEZ
Name'sDEEZ
Earth
