RCA's into this amp
flyfishing
I am just a rookie at auto sound so excuse my ignorance. I am used to seeing Left and Right RCA connections into an amp. This amp does not label them like that. This one say Channel 1 2 3 4.
Which RCA's go into which Channels???
Thanks,
Doesn't matter which RCA goes where, as long as the input matches the output. If you put your front left RCA into channel 1 input, you must hook your front left speaker to channel 1 output.
I am just using this JL Audio Blue Tooth Receiver and it has (2) RCA outputs, red and black. I want to run (2) 6x9's and (1) small subwoofer.
If I have (2) RCA outputs what do I need to do to for this speaker configuration?
Thanks,
Thanks,
Plug into channel 1 and 2 and switch the switch to the left of the RCA connectors to 2 channel mode
Thanks,
I've never seen a product like that. Why not just run a bluetooth amp?
EMR sniffer or AM/FM sniffer. small radio but with a probe antenna to it. It gives you the specific location on the ground loops. This device...
26
Glad to hear it was a simple fix and the amp is working again. The 9v reading indicated it was likely a bad connection somewhere.
Many moons ago I was heavy into Car Audio Systems(Iasca stuff) but a ton of things have me removed and knowledge forgotten so I need a refresh. I...
flyfishing
flyfishing
Orange County
flyfishing
    May 31, 2024
